AP3000/X Specifications
        The
            AP3000/X combines powerful 802.11ax Wi-Fi 6E technology, advanced security, and ML/AI
            cloud management capabilities as an enterprise-class solution in a small, low-power
            package that allows you to deploy high speed and highly secure Wi-Fi.Advanced Radio
                Technology
Dual-Radio Design
                - 2.4/5 GHz (2x2:2)
                - 5/6 GHz (2x2:2)
Universal Hardware Platform
                - On-Premises: WiNG OS (Distributed
                    in a future release on select models), ExtremeCloud™
                    IQ Controller (Centralized)
                - Cloud: ExtremeCloud IQ
Operational Modes
                - Mode 1: 2.4 GHz/5 GHz Data
                    Radios
                - Mode 2: 5 GHz/6 GHz Data
                    Radios
Designed for harsh environments
                - External antennas and extended
                    temperature range -20°C to +55°C
Cellular Coexistence Filter (CCF)
                - Minimizes the impact of
                    interference from cellular networks
Fully Functional Wi-Fi with 802.3af
Smart Management Choices
                - ExtremeCloud IQ for public,
                    private, and ExtremeCloud Edge cloud management capabilities
                - ExtremeCloud IQ Controller for
                    on-premises requirements
            The AP3000/X Wi-Fi 6E access point, with two 2x2:2 radios, provides high- efficiency,
                high-performance 802.11ax aggregate data rates up to 4.8 Gbps in the 6 GHz, 5 GHz,
                and 2.4 GHz bands.  The AP3000/X features a fully functional Multi-Band filter,
                enabling simultaneous operations with no performance degradation between all the 5
                GHz frequencies and the entire range of 6 GHz frequencies (U-NII-5 thru U-NII-8
                bands).*
            * Country dependent
